missing handles in power window
COW Forums : DaVinci Resolve
adam chesbrough
on Dec 11, 2013 at 10:28:47 pm
I am watching a tutorial and when a power window is added to a node the shape appears in the viewer. I do not get the shape nor do I have control over the power window mask. I thought it was a "view" option but I can't find it anywhere. Where the power window is supposed to be there is a layer name column. Im missing something easy I think
Macbook Pro Retina: 2.6GHZ i7, 16GB RAM 1600MHz DDR3, GT 650M 1GB RAM
Hackintosh (Sandy Bridge): i5 2500, 16GB 1333MHz DDR3, Nvidia GT640 2GB RAM
OWC 4TB RAID0 (using esata)
Tempo SATA Pro ExpressCard/34 (6Gb/s)
Echo ExpressCard Pro Thunderbolt Adapter
Glenn Sakatch
Re: missing handles in power window
on Dec 12, 2013 at 2:49:36 pm
First things first. In the screen shot you provided, you have not picked a window yet.
You have to select "on" next to 1 or more of you window shapes.
Glenn
adam chesbrough
on Dec 12, 2013 at 2:51:31 pm
Yes I have done that as well as picked on next to a bunch of them. I have attempted on while all different does are selected as well. The screen shot was just to show the area where the mask should appear and instead I have a the "name" column (I have also named them to see if it switches after I name a power mask...nothing happens.
Dwaine Maggart
on Dec 12, 2013 at 4:54:29 pm
View menu / Window Outline > On
Dwaine Maggart
Blackmagic Design DaVinci Support
