GTX 770 4GB single GPU system...
COW Forums : DaVinci Resolve
Jonathon Lee
on Aug 12, 2013 at 8:06:05 pm
Has anyone here used a GTX 770 4GB GPU in a single card Mac Pro (2010or 2012). I want to replace a GTX 570 2.5GB. I do render some 4K & UHD program, but was wondering:
1) What impact do connected GUI displays have on GPU RAM (GUI displays: 1x 2560x1440, 1x 1920x1200, 1x UHD)
2) These cards have 1x 6-pin & 1x 8-pin AUX power ports. What would I use to adapt the 8-pin power connector on the GPU)?
thanks,
Jonathon
EricBowen
Re: GTX 770 4GB single GPU system...
on Aug 21, 2013 at 6:35:19 pm
Just get the PCI-E 8 pin adapters that go to 2 PCI-E 6 pin connectors. The Card should be fine. People are already using the 780GTX and Titan with those.
Eric-ADK
Tech Manager
Eric Hansen
on Aug 24, 2013 at 7:29:18 pm
hey Eric
The 780 and Titan don't require additional power in a Mac Pro?
e
Eric Hansen
Production Workflow Designer / Consultant / Colorist / DIT
http://www.erichansen.tv
EricBowen
on Aug 26, 2013 at 2:54:05 pm
To stay within spec those cards would yes, but the max power draw is only 25W over and all the Nvidia cards will throttle via C-States if required. A 2nd PSU though is the safe way to configure.
Eric-ADK
Tech Manager
