Deflicker slowmo footage
COW Forums : DaVinci Resolve
Felix Gorbach
on Jul 31, 2013 at 8:46:15 pm
Dear DaVinci Gurus,
Made a few Redclips with different fps - from 100 to 300fps - they look realy great - and it´s asthonishing what you can get out from the footage with DaVinci. I´m impressed.
Shot the footage in Europe in a small studio - and yes - what I expected happend - From the lights I have of corse a lot of flickering. Is there a way to get around this issue in DaVinci - or should I use some after Effects Plugin after grading? Do you have any suggestions for a workflow for this issue?
Thanks a lot and best wishes,
Felix
Dmitry Kitsov
Re: Deflicker slowmo footage
on Jul 31, 2013 at 11:05:15 pm
Boris has something for deflickering, haven't used it though.
Felix Gorbach
on Aug 1, 2013 at 5:48:09 pm
Hy Dimity,
Thanks for the tip. It works with BCC Flicker Fixer - new in suite8 - it has some adjustments that allows to finetune to the result I needed. So anyway, I would give definitely a try to bcc.
thanks,
Felix
