Resolve 9.1.4 No Audio and Very Fast Playback
COW Forums : DaVinci Resolve
Amos Kim
on Jun 26, 2013 at 4:20:07 am
Hi all,
I'm new to Resolve. I seem to have two problems: can't get audio output (I see meters but no audio heard) and playback of untouched video clips (DSLR h264, ProRes LT and even the longer tutorial clip included with Resolve) in the Color room plays unusually fast. Anybody encounter a similar issue? I'm running the 9.1.4 version on my Mac OS 10.8.2 Hackintosh with GTX 580 Classified. I've got installed Cuda Driver 5.0.37 and GPU Driver 304.00.05f02. I'm hoping this a simple fix and nothing really defective with my system. Any input is appreciated.
thanks.
Rohit Gupta
Re: Resolve 9.1.4 No Audio and Very Fast Playback
on Jun 26, 2013 at 2:29:38 pm
Can you open preferences, save, and restart app. I think your system is configured for decklink and it has gone missing.
Amos Kim
on Jun 27, 2013 at 3:50:17 am
Wow that fixed everything! Much appreciated Rohit! Thanks!
Sascha Engel
on Jul 7, 2013 at 5:07:56 am
Hi Amos,
I am about to get my brand new Hackintosh now, with a 2GB NVidia 680 card.
I wonder, how is your experience with Hackintosh in combination with resolve? It works all fine? Any workflow problems? Can the CPU and GPU manage to power hungry app?
Thanx for feedback.
Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
Amos Kim
on Jul 7, 2013 at 5:20:14 am
Hey Sascha,
I've been able to get it to work relatively well. I experience some kinks in playback in the color page, but nothing critical.
I haven't looked into the 680 card, so I can't comment about it, but for the most part, my 580 seems up to the task so far.
If there was any advice I would give to a hackintosh newbie (which I consider myself being also), it would be to make sure you have all the Motherboard BIOS settings correct. A LOT of problems stem from incorrect BIOS settings. Do your research on TonyMacx86, which is an amazing resource.
Sascha Engel
on Jul 7, 2013 at 5:26:28 am
What exactly you mean by "some kinks in playback in the color page"?
Thanx.
Greetings,
Sascha Engel
Amos Kim
on Jul 7, 2013 at 5:37:06 am
Every once in a while, I experience the frame rate ramping up and down and creating jerky playback. When I experience that, I just pause and playback again, and it plays normal.
I haven't been able to find the cause so far and it seems like I'm the only one who has reported anything similar online. Many have told me it's probably not any hardware or Davinci software malfunction but just due to the mere fact that I'm using non standard Mac hardware. There's probably a hack or patch to fix this but at this point, I've decided to live with it, until a solution presents itself.
Sascha Engel
on Jul 7, 2013 at 5:34:32 am
And one more Q: What NLE or other Video editing related apps you are using on your Computer?
They all work fine or you encountered other apps, that have a problem on the HacMac?
Thanx a lot.
Greetings,
Sascha Engel
Amos Kim
on Jul 7, 2013 at 5:39:31 am
Other than CS6 Premiere Pro not detecting my CUDA GPU once in a while, it has run relatively smoothly. When I encounter this, I just quit and restart, which usually gets Premiere to find my CUDA device.
Sascha Engel
on Jul 7, 2013 at 5:49:37 am
How often does that happen?
Basically, you can use PS, AE and PPro without any problems?
What about FCP 7 & X? You are using it? It works ok?
Thanx again.
Sascha Engel
Amos Kim
on Jul 7, 2013 at 5:54:36 am
1/5 times when I first open the CS6 Premiere Pro. I haven't used FCP, PS, or AE with my system yet.
Sascha Engel
on Jul 7, 2013 at 5:55:56 am
Thanx.
Sascha Engel
Amos Kim
on Jul 7, 2013 at 5:59:27 am
If you encounter same issues and are able to solve them, please do not hesitate to chime back in :)
thx
Sascha Engel
on Jul 7, 2013 at 6:14:15 am
Sure, I can do that.
What other softwares are you using? Just in case we have overlapping ones.
Greetings,
Sascha Engel
Amos Kim
on Jul 7, 2013 at 6:21:54 am
Thanks. I primarily use premiere CS6 and DaVinci, but I'm planning to venture into Audition & AE CS6 soon.
Good luck with your build!
Sascha Engel
on Jul 7, 2013 at 6:29:17 am
No luck needed. I need the machine on Pro Level, so I got it build by a Pro Tecnician, who makes those machines here in Israel, since real Macs are out of the world expansive here.
Greetings,
Sascha Engel
