Removing Dead Pixels
COW Forums : DaVinci Resolve
Ben Edwards
on May 1, 2013 at 8:30:21 pm
Hi, thanks for everybody's help so far.
One on the cameras the footage was shot on has dead pixels (which show up as white spots). Its a dance pice in a theatre so the background it black. Was wondering if it was possible to set a qualifier on white pixels so I can turn them down. Tried but no luck. Cant use hit them with picker, if I zoom in enough to get then they are off screen (shame you cant scroll around window when it is zoomed in.
Any ideas?
Ben
Ben Edwards - Freelance Picture Editor
http://www.funkytwig.com
i5 550, Windows 7 / Mac Lion, Nvida 550 Ti, 8GB Mem
Rohit Gupta
Re: Removing Dead Pixels
on May 1, 2013 at 10:52:13 pm
You can use the middle mouse press and drag to scroll around the image.
Alan Gordon
on May 15, 2013 at 10:21:45 pm
THIS is changing my life forever! Wish I knew about this years ago!
-Alan
Ben Scott
on May 2, 2013 at 9:45:53 am
have a look at boris BCC effects they have a pixelfixer
Neil Patience
on May 3, 2013 at 12:44:15 am
Hi Ben
Digital Heaven have a pixel fixing plug-in for FCP4-7 and FCPX called Reincarnation. If you use those editing platforms worth a look. Its $59.00US
http://www.digital-heaven.co.uk/plugins
best wishes
Neil
http://www.patience.tv
8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
Joseph Owens
on May 3, 2013 at 3:17:56 pm
[Ben Edwards] "Was wondering if it was possible to set a qualifier on white pixels so I can turn them down."
Stuck pixels don't move around (but moving objects in the picture content obviously complicates the correction) so what I normally do is crate a teensy weensy power window and set a blur so that the pixel is naturally migrating towards whatever the adjacent pixel values are.
This approach breaks down whenever an edge crosses the qualifier, so it requires a keyframe/tweak. So the technique either works a treat or (depending on picture activity) is more trouble than its worth.
However, it doesn't require any plugins or roundtripping pass-back and forth.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Ben Edwards
on May 3, 2013 at 6:41:46 pm
Thanks, will give it a try, nice solution. Pitty there is more than ong;).
Eli Bierwag
on Jul 11, 2013 at 6:17:54 pm
I use your power window technique as well, but I usually do a noise reduction rather than a blur. Blur is less resource intensive (won't slow down the machine) but NR will be less visible.
