9.0.4 to 9.1 PROJECT AND DATABASE COMPATIBILITY
COW Forums : DaVinci Resolve
andrew sableton
on Apr 19, 2013 at 10:35:37 pm
Hi All,
Are there any issues in moving projects between a 9.0.4 system and 9.1 through the export project command?
Also if I do promote all systems to 9.1, will existing 9.0.4 projects promote to 9.1 without problems?
Thx
AS
brandon thomas
Re: 9.0.4 to 9.1 PROJECT AND DATABASE COMPATIBILITY
on Apr 23, 2013 at 4:25:39 am
Should be totally fine.
I'd recommend backing up the database, importing the new database with a new name, and upgrading that if you don't want to start a completely fresh db for 9.1.
