Blue only node
COW Forums : DaVinci Resolve
Jordan Mena
Blue only node
on Feb 28, 2013 at 1:33:40 am
Is there a way to create a node where it gives me a blue only effect similar to a button you would press on a broadcast monitor. Trying to dial in my colors on my HDTV as best I can till I purchase a broadcast monitor worthy of this forum :)
Thanks, J
Juan Salvo
Re: Blue only node
on Feb 28, 2013 at 3:44:45 am
You can't do this in the outgoing signal path, it has to be done on the display. It's literally shutting off R and G gun in a CRT display, doesn't matter in a flat panel. But if you want to do it anyway use a blue gel over your eye.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Jordan Mena
Re: Blue only node
on Feb 28, 2013 at 5:23:13 am
Are you saying it's a waste of time trying to look at the blue channels on my LCD?
I can't seem to find a proper reference to calibrate. I know it's not Rec 709 I just want to see a balanced signal through my 32" Samsung 1080p HDTV.
My client doesn't care that it's not a broadcast monitor but I want to at least try to get a decent reference out of it. Basically a stop gap until I grab a BM.
Juan Salvo
Re: Blue only node
on Feb 28, 2013 at 5:54:33 am
Not saying it's a waste of time to try, saying its not relavent to solide state displays. I suppose you could still use smpte bars and a blue gel to adjust saturation, but phase/tint, should not need adjusting in a digital world.
That said, good advice and a gel recommendation here, from a doc aimed at CRT displays.
http://www.synthetic-ap.com/tips/calibrate.pdf
Jordan Mena
Re: Blue only node
on Feb 28, 2013 at 6:04:04 am
Thanks Juan.
