Any opinions or suggestions on this workstation i'm thinking of...
COW Forums : DaVinci Resolve
Javier Martos Valladares
on Feb 21, 2013 at 10:38:27 pm
Workstation. HP Z620. WM439EA
Description Z620/ RMT/ Intel Xeon E5-2620/ 16GB/ 1000GB SATA 7200/ DVDRW/ Win7Pro 64
Form Fact RMT
Processor 2 Xeon E5-2620
Processor Specs 2 Intel Xeon E5-2620 (2.00 GHz, 15 MB cache, 6 cores)
GHz 2.00GHz
Chipset Intel C602
GB 16GB
Memory Specs 16 GB 1600 MHz DDR3 ECC Unbuffered RAM
Max Mem 48GB
HDD 1TB
Hard Drive Specs 1 TB 7200 rpm SATA NCQ
Type SATA
Then 2 GPU: quadro 600 for gui and nvidia gtx 580 for processing.
For monitoring: GUI any suggestion (2560x1440 is the preferred screen resolution)
Reference: I have an Hp 2480 zx dreamcolor as a grading monitor so i will have to ad a BM sdi output card width 4:4:4 output ( don't know wich one) and hdlink for sdi-displayport conversion for the dreamcolor.
Sorry for my poor english.
Javier Martos.Colorist
http://www.24fps.es
Juan Salvo
Re: Any opinions or suggestions on this workstation i'm thinking of...
on Feb 22, 2013 at 3:15:25 am
Go by the config guide, blah, blah, all that jazz. From the specs sounds ok. For whatever that's worth. Nothing about the config sounds off. Keep in mind it won't be the fastest system on earth, but would certainly be capable for HD/2kish type stuff.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Nurali Kushkov
on Aug 2, 2014 at 6:21:38 pm
Javier how did it work out with HP monitor?
Im considering similar setup but with eizo CS230 + aja hi5 plus.
on Aug 25, 2014 at 9:27:52 pm
Don't know about that Eizo monitor image quality but Eizo monitors have much better calibrations capabilities than the hp dreamcolor, also Aja lut box is a good relatively cheap one, much better than the HDdlink from BM.
http://www.javiermartoscolorist.com
