9.1 Oddity???
COW Forums : DaVinci Resolve
Yoram Tal
9.1 Oddity???
on Jan 24, 2013 at 11:29:01 pm
Hi All
I downloaded and installed Resolve 9.1 and I have noticed an oddity, when I stop on a frame the picture seems to split to 4 and pull ever so slightly to the corners. The result is softer image on freeze.
This only happens on the video monitor not on the computer screen.
I am using 720p footage and playing out both fields.
I am using Black magic UltraStudio 3D box.
I have the latest Cuda driver.
Anyone else seeing this?
Thanks.
Tal
Al Arnold
Re: 9.1 Oddity???
on Jan 30, 2013 at 8:33:47 pm
Is this on a project that existed before you upgraded, or is it a project that you created after the upgrade?
Yoram Tal
Re: 9.1 Oddity???
on Jan 30, 2013 at 8:58:14 pm
Before the upgrade. The problem seems to happen only on client monitor and only on 720p
Al Arnold
Re: 9.1 Oddity???
on Jan 30, 2013 at 9:21:06 pm
I had a similar problem. I had a project started before the upgrade to 9.1. My issue was that when I hit play the color would shift. I didn't have the problem on a new project. Try toggling some master project settings (I toggled output lut to waveform), save, reboot, and see if it helps. This worked for me.
