importing .wav files
COW Forums : DaVinci Resolve
paul schilens
on Jan 10, 2013 at 4:22:10 pm
I seem to be having trouble importing .wav files to link with my .ari files. I keep getting an error message saying: 'failed to read audio file...'
I'm still using Resolve 8.1, but that really shouldn't make a difference with this issue.
Can you not link .wav files to .ari files? Doesn't make sense.
Any solutions?
...Always learning
Peter Chamberlain
Re: importing .wav files
on Jan 11, 2013 at 1:59:16 am
From your description it sounds like the wav file has the wrong sample rate, should be 48KHz, or bit depth.
paul schilens
on Jan 11, 2013 at 1:38:49 pm
[Peter Chamberlain] "From your description it sounds like the wav file has the wrong sample rate, should be 48KHz, or bit depth."
Hmmmm, everything is right: 48kHz, 32 bit.
Any other suggestions?
...Always learning
