Window Outline shortcut strangeness - and feature request
COW Forums : DaVinci Resolve
Laco Gaal
on Dec 17, 2012 at 9:49:16 pm
I have Davinci Lite 9.0.4 installed on a Mac Pro, where the Cmd-Shift-C shortcut doesn't work
I have Davinci Lite 9.0.4 installed on a Retina Macbook Pro, where the Cmd-Shift-C shortcut works.
This allows me to quickly show the mask to the DOP, and then immediately turn it off. Without this, it's much slower...
Also would it be possible to use the Davinci 8 shortcuts? For example disable all grades with the arrows are faster for me, than finding Alt-D..
Thanks.
Andy Winter
Re: Window Outline shortcut strangeness - and feature request
on Dec 18, 2012 at 12:06:42 pm
same on my machine. since 9.0.4 the shortcut seems to be broken or changed.
weird that it seems to work on your macbookpro.
andy
Laco Gaal
on Dec 18, 2012 at 12:18:37 pm
Sorry...on the retina macbook i have the 9.0.3 installed!
So it seems to be a bug in the 9.0.4 release.
Andy Winter
on Dec 18, 2012 at 12:51:45 pm
i would guess it is not a bug, just a change of a shortcut. you can map it yourself again
with osx tools (system preferences -> shortcut)
Laco Gaal
on Dec 18, 2012 at 12:58:03 pm
You can't because osx only lets you map a shortcut to one menu item. The Cmd-Shift-C shortcut lets you cycle between the options
Andy Winter
on Dec 18, 2012 at 2:33:35 pm
ok. one point for you :)
right, so is it a new shortcut or really a bug? can someone from davinci chime in?
andy
Rohit Singhal
on Dec 19, 2012 at 2:57:47 am
The Window outline shortcut has been changed to option-H. You can switch to Resolve 8 shortcuts by going to Config->Editing.
Please find the updated shortcuts list here
http://www.blackmagicdesign.com/support/detail/supportnotes/supportnote?sid...
Laco Gaal
on Dec 20, 2012 at 10:43:07 am
Thanks Rohit,
missed the updated list! Hope to get used to it in a few weeks;)
Thanks again
