Changing Work Monitor in Davinci?
COW Forums : DaVinci Resolve
Reuben Fink
on Dec 17, 2012 at 2:15:48 am
I am running two monitors and a plasma display. Currently in OSX I have my left monitor setup as monitor #1 and the right is #2. What I want to do is have my scopes on the left monitor and the main resolve interface on the right monitor without changing the actual configuration in OSX system prefs. Is this possible? It seems like Davinci defaults to the #1 monitor and doesn't let you customize placement. Am I right about that?
Thanks.
OSX 10.8.2
Equipment: 2.8 ghz 8 core Intal Mac Pro 3,1 Early 2008, 20 gig of ram
Aps: CS6 Production Premium, FCP Suite, Avid Media Composer
Timo Teravainen
Re: Changing Work Monitor in Davinci?
on Dec 17, 2012 at 8:27:53 am
As far as I know you have to change it from OSX prefs. Or just physically swap the displays:)
Reuben Fink
on Dec 19, 2012 at 11:56:04 pm
That seems to be the case. Thanks.
OSX 10.8.2
Charlie Chang
on Jan 2, 2013 at 4:51:12 pm
[Timo Teravainen] "As far as I know you have to change it from OSX prefs. Or just physically swap the displays:)"
Is this the same for Windows too? That would be a great inconvenience. I have tried to customize the interface to go across two monitors and I couldn't even do it.
