MotherBoards
COW Forums : DaVinci Resolve
Simon Blackledge
MotherBoards
on Nov 24, 2012 at 8:50:55 am
So the Asus is in the spec but is there anything out there that will allow the below ? Or do I just get the Supermicro chassis now rather than an interim PC ?
1x690
1x600
1x decklink
1x R680
would like to put a 1x 10Gig Nic in also.
ta
s
Peter Chamberlain
Re: MotherBoards
on Nov 25, 2012 at 6:23:32 am
HI, your board combination is unusual but either way, following the config guide Supermicro system will offer the best performance as it has four independent x16 slots.
Peter
alex B Carr
Re: MotherBoards
on Nov 25, 2012 at 7:29:55 am
I've got the Asus Z9PE 2011 socket Dual Xeon. Currently just one GPU GTX 680, but 10GE, HD/SDi, and x2 ATTO cards.
I'd say Davinci works pretty well in Windows 7 and Mac Mountain Lion. The GTX 680 was overheating so I switched to a water cooling setup. Temp dropped from 75C+ down to 35C.
Simon Blackledge
Re: MotherBoards
on Nov 26, 2012 at 9:30:08 am
Hi Peter,
Why do you save it's unusual ?
1x ui card
1x gpu card
1x sdi i/o
1x raid hba
Surely most people would require these in a system to run Resolve?
Or did you mean something else?
Simon
Al Arnold
Re: MotherBoards
on Dec 8, 2012 at 5:58:21 am
Currently running this board w/ multiple GPUs, & blackmagic decklink.
Resolve working perfectly:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131798&Tpk=asus%20...
If you'd like dual CPUs:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131817&Tpk=asus%20...
I have no experience with this board though.
