Large Format Still Frames
COW Forums : DaVinci Resolve
Robert Due
on Nov 19, 2012 at 10:34:40 pm
Wondering if this is possible in Resolve:
An editor wants me to take some tiff files that are of different sizes (5000 x 3000, 2000 x 1080, etc.) and color grade them in Resolve. He wants them back as tiff files at their respective original frame sizes.
Do I do these in separate projects for each frame size? Can I get Resolve to fit these on my monitor and then render out at the original size? Anybody come across this yet?
Robert Due
Editor / Colorist
INDEPENDENT EDIT
DaVinci 9.0
OSX 10.7.5
MacPro 8-core 4,1 2.93 Ghz
8GB RAM
Nvidia GT120/GTX570 (CUDA 5.0.36)
Decklink Extreme3D+
Panny BT-LH1710P/ Panny BT-LH2600W
Tangent Wave
Sareesh Sudhakaran
Re: Large Format Still Frames
on Nov 20, 2012 at 4:32:11 am
Resolve is resolution and frame rate independent. You should have no problems.
http://www.wolfcrow.com - Workflow information and support for filmmakers, photographers, audiographers and videographers.
Peter Chamberlain
on Nov 20, 2012 at 8:25:14 am
The challenge I think you will have is running out of GPU memory. A 5k x 3k image is quite big, a lot bigger than DCI 4K for example, and thus 3GB or more GPU ram might be needed.
Peter
Joseph Owens
on Nov 20, 2012 at 9:16:35 pm
Wait... does Resolve now support single frame graphic files... TIFF, JPG, PNG, etc.?
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Paul Provost
on Nov 22, 2012 at 4:45:53 am
I've asked this without response from bmd, because one of them posted a workaround I can't find.
Apparently if you bring a tiff into media pool and change frame rate to 1 fps or something it recognizes it? Have not tried it. Not quite the same as recognizing stills from an XML a la apple color...
http://www.4Kfinish.com | owner-colorist | Hollywood, CA
http://www.facebook.com/4kFinish
