Workflow for DVD dailies
COW Forums : DaVinci Resolve
justin lovell
on Sep 6, 2012 at 4:30:21 pm
Hey fellas,
Can you recommend a workflow for creating DVDs / Dailies from resolve?
My originating material is Regular 16mm 4x3 over scanned showing sprocket holes. (from film transfers)
Currently, I'm rendering out HD files (showing the overscanned image sprocket holes/framelines)
import to after effects
resize image smaller to 45% to a 720x480 timeline
exporting mpeg 2 DVD file (constant bitrate 7mbps)
import to encore
export DVD
Is there a faster or better workflow?
Justin Lovell /Assoc. CSC
cinematographer//
8/16mm>2K.transfers
http://www.framediscreet.com
Joseph Owens
Re: Workflow for DVD dailies
on Sep 6, 2012 at 7:00:02 pm
[justin lovell] "faster or better workflow?"
You might consider skipping the resize if you are not exporting it directly from After Effects and it turns out to be faster, because you can crop/resize in Compressor. You might be able to go from the dpx sequence for each reel.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
justin lovell
on Sep 7, 2012 at 7:52:17 pm
Is it at all possible to directly create MPEG2 DVD files straight from resolve?
cinematographer//
8/16mm>2K.transfers
