Converting to quicktime file is 30,000 fps?
COW Forums : DaVinci Resolve
Dustin Moore
on Jul 4, 2012 at 3:42:19 pm
I have a 30 second 1080i DNxHD mxf file that I
would like to convert to quicktime cineform yuv 10 bit.
If I right click on the file in Browse|Clip details and hit
convert file with that format, I get a file that
is unplayable in Quicktime, Vegas or anything else I
can find.
Mediainfo tells me that the file has a frame rate of
30,000 fps. I've included the output later in the post.
The file is about 8 times larger in GB than I think it
should be.
My config panel looks this this: http://i.imgur.com/Pn51j.jpg
Mediainfo output:
General
Complete name : F:shitkittensQuickTimeCapture0001V.mov
Format : QuickTime
Format/Info : Original Apple specifications
File size : 9.20 GiB
Duration : 60ms
Overall bit rate : 0 bps
Encoded date : UTC 2012-07-04 16:31:46
Tagged date : UTC 2012-07-04 16:35:15
Writing library : Apple QuickTime
Video
Format : CineForm
Codec ID : CFHD
Codec ID/Info : CineForm High-Definition (HD) wavelet codec
Duration : 60ms
Bit rate mode : Constant
Bit rate : 0 bps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30 000.000 fps
Scan type : Progressive
Bits/(Pixel*Frame) : 21.337
Stream size : 9.20 GiB (100%)
Language : English
Color primaries : BT.709-2, SMPTE 274M, SMPTE 296M
Transfer characteristics : BT.709-2, SMPTE 170M, SMPTE 274M, SMPTE 293M, SMPTE 296M
Matrix coefficients : BT.709-2, SMPTE 274M, SMPTE 296M
Menu
Duration : 60ms
Language : English
Encoded date : UTC 2012-07-04 16:35:15
