Post mix gain problem
COW Forums : DaVinci Resolve
David Scott
on Jun 26, 2012 at 6:25:50 am
Hi folks
I'm new to Resolve so please answer this in small simple words!
I've created a complex effect with lots of nodes, but now overall its a bit heavy and I need to back it off by mixing the effect 80% with the original media. I understand I can do this using a Layer Mixer node, with one input connected to the previous node in the chain, and the second input connected back to the output of the first node in the chain. Then use the Post Mixing Gain slider in the Key tab of the Layer Mixer node to adjust the effect amount. Makes sense. However the effect remains at full strength regardless of where I position the slider!
Any thoughts?
Thank you.
David Scott,
Senior Editor,
GOD TV (UK)
David Scott
Re: Post mix gain problem
on Jun 26, 2012 at 6:41:06 am
Hi David
It's not the Layer Mixer node you adjust, but the Post Mix Gain of the node FEEDING it!
David Scott,
Senior Editor,
GOD TV (UK)
David Scott
on Jun 26, 2012 at 6:42:56 am
Excellent advice David - thank you. Just wish I'd realized BEFORE posting on the forum and not 2 mins afterwards! Obviously talking it through helped me work it out - Haha!
David Scott,
Senior Editor,
GOD TV (UK)
