When Split Clip manually Clip node affects all clips?
COW Forums : DaVinci Resolve
Jim Larsson
on Apr 19, 2012 at 9:33:58 am
I am splitting a video file manually in DaVinci Resolve lite (mac) with the Split Clip tool in the conformtab. After doing that when choosing a clip in the Colortab and grading the clip node (not the track node) the node affects all clips in the color tab as if it all was a long single clip.
How do I get this working as separate nodes for each clip?
John Michaels
Re: When Split Clip manually Clip node affects all clips?
on Apr 19, 2012 at 6:22:34 pm
In the Color tab, select your clips, right-click, and choose "Batch Unlink." That will make each clip independent despite being from the same source.
John Carter
on Jan 4, 2013 at 5:45:16 pm
This option are always in the version 9? I'm searching this option and I can't find this .... :S
Jason Brown
on Mar 18, 2013 at 10:51:36 pm
I am also searching for this in version 9. Any luck finding how to batch unlink split clips?
Jason Brown
on Mar 18, 2013 at 11:11:20 pm
Issue resolved -- in the color timeline, select the clip and right click. Enable "use local grades".
