optimizing my r3d playback?
COW Forums : DaVinci Resolve
jeremie galan
on May 9, 2016 at 1:41:15 pm
With all the redner cache options and other stuff to optimize playback i m a little lost on how i should proceed. Heres my setup for a r3d weapon project ( 5k hd ).
My rig is a i7 5960x ( 8 cores )
Dual Titan-X
64 Gb of ram
media are on a RAID 0 ( blackmagic speed test says 1200Mb/s in read speed ).
Obvisoulsy i'm trying to do 25 fps playback... and now it's only getting 15/20fps with debayering set to half good.
Timeline is hd 1920x1080
any ideas on good starting block to getting better results?
Regards
J.
Michael Gissing
Re: optimizing my r3d playback?
on May 10, 2016 at 3:00:31 am
Presume this is a Resolve Pro (paid version not the free) and you have both Titan X cards enabled for CUDA.
What are your settings for playback scaling presuming you are scaling the r3d to a timeline with different pixel aspect to the camera original. I have had no issue getting 25fps with a single Titan X playing 8:1 r3d scaling to HD from a Dragon.
Should add my settings for scaling are for best playback and the final renders are to force best debayer etc
Marc Wielage
on May 11, 2016 at 3:16:46 am
How does it work in 1/4-res good? That should be good enough for realtime playback, and you figure that's roughly the equivalent of the HD screen on which you're monitoring.
