Can't install DaVinci
COW Forums : DaVinci Resolve
Alekasandr n.
on May 4, 2016 at 9:34:02 am
Hi everyone
After uninstallation of previous version (12.5b1) I can't install DaVinci Resolve at all. Any Version including 12.5b2 and 12.3.2. After extracting of installer error message appears: "The feature you are trying to use is on a network resource that is unavailable"
Screenshot: http://imagizer.imageshack.us/a/img924/6684/8Bo1d4.jpg
and locating the file in temp folder doesn't help either. The error message appears that "the file is not a valid installation package for DasVinci Resolve"
Screenshot: http://imagizer.imageshack.us/a/img923/8965/0HrPMI.jpg
Does anybody know a way to resolve this?
Or where solution might be. Regisry, folders, permissions or anything to dig into
System - Windows 10 x64
-Aleksandr
Alekasandr n.
Re: Can't install DaVinci
on May 4, 2016 at 12:11:27 pm
Solution: I've found in the registry thread under HKEY_USERS where DaVinci installation info is stored and deleted it. Then everything worked as it should!
Steve Mullen
on May 18, 2016 at 2:27:58 am
Curious, did you also use the Windows UNINSTALL control panel before trying to install a new version? If you did, I wonder why the Registry wasn't cleaned.
