Relinking Avid sequence in Resolve that uses Subclips.
COW Forums : DaVinci Resolve
Bryce McNamara
on Apr 26, 2016 at 11:12:51 pm
Hi there,
Could somebody please help me out with this issue.
My workflow starts in Resolve. I create ProRes proxy files named exactly the same as the source files. These are then sent to Avid to edit a sequence.
If I edit directly using those clips - ie. without subclipping - and send back an AAF, everything relinks perfectly in Resolve.
If I use subclips, the clips in the Avid sequence have names that no longer match the original source footage and this AAF version does not relink in Resolve.
I feel like there's an essential step I'm missing in solving this issue. There must be a simple way to use subclips and still link easily back to the source files in resolve.
I really need to sort this out for an upcoming project where subclips will be used, any advice or assistance would be greatly appreciated.
Cheers
Glenn Sakatch
Re: Relinking Avid sequence in Resolve that uses Subclips.
on Apr 27, 2016 at 6:46:24 pm
can you relink your avid sequence back to the original clips before you send it to resolve?
(I don't do a lot of subclipping, so just spit ballin here)
Glenn
