Resolve won't start
COW Forums : DaVinci Resolve
jeremie galan
Resolve won't start
on Mar 20, 2016 at 4:16:45 pm
New install of windows 10
i7 5960x , dual titan x ( not and 64gb of ram.
Resolve won't start. i ve unsintalled and reinstalled it again and again, i double click on the resolve icon and nothing happen.
any help?
ps : i ve disabled sli and took out the physical bridge too
David Roth Weiss
Re: Resolve won't start
on Mar 20, 2016 at 5:33:23 pm
There is no mention in your post of which version of Resolve you're trying to install.
Have to checked the Resolve documentation to make certain your version supports Windows 10?
Perhaps you should yank the 2nd GPU to see if Resolve will start with a single card? (If it does you can at least identify the issue and then try to resolve the issue(s).
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
jeremie galan
on Mar 20, 2016 at 8:08:33 pm
I ve tested 12.3.2 and 12.3.1. I ve tested with only one titan x, still doesn't work.
Werid thing is that i did the exact same setup on the exact same machine earlier this month ( before reformating ) and it worked.
Robert Ober
on Mar 21, 2016 at 2:59:46 pm
Do you get an error?
Tried different Nvidia driver? Turned off Firewall and antivirus?
Robert
Robert A. Ober
IT Consultant, Vidcaster, & Freelancer
http://www.infohou.com
Houston, TX
jeremie galan
on Mar 21, 2016 at 5:28:43 pm
Just turned firewall off, and reverted to older nvidia drivers still doesn't work :(
