Problems with Framerate (59.54 FPS and 23.976 FPS)
COW Forums : DaVinci Resolve
Andrew Hempfling
on Mar 18, 2016 at 8:01:14 pm
I've been working with DaVinci Resolve 12 for less than a day, and I have no idea how to solve these problems using solutions that I'd use in other NLEs.
I shot some good looking martial arts footage at the rates of 23.976 FPS at 1080p and 59.94 FPS at 720p. My project settings are at 1080p, 23.976, and playback is also at 23.976.
Project Settings:
I added some of of the clips at both framerates to the media pool and the behaved just fine. The 23.976 clips play at normal speed, while the 59.94 clips play in slow motion just as intended. (Take note: the metadata also lists the clip at 59.94.)
Media Pool:
Now we move on to the timeline. Here's where everything goes wrong. The same clips are listed as 23.976, and they play in real time, not slow motion.
And if I try to play at 40% speed, it comes choppy out like I'm stretching a 23.976 clip, not a 59.94 clip.
Why aren't slow motion clips in slow motion?
Timeline (with clip info):
Software: DaVinci Resolve 12
Hardware: 13-inch MacBook Pro with Retina display
2.7GHz Dual-core Intel Core i5
128GB PCIe-based Flash Storage
Intel Iris Graphics 6100
Camera: Canon EOS Rebel T3i
Marc Wielage
Re: Problems with Framerate (59.54 FPS and 23.976 FPS)
on Mar 21, 2016 at 5:11:54 am
Use Clip Attributes to change the speed of the clip to 23.976fps. Don't change the speed in the edit page per se. Be aware that once you change the clip speed, this will change the edit since the clip will now be X% longer than it was before.
© 2018 All Rights Reserved
