Resolve render shorter clips than original!
COW Forums : DaVinci Resolve
HAl Ray
on Mar 1, 2016 at 6:37:19 pm
Hello,
I need your help.
This is urgent.
I exported a finished timeline from Final Cut X to Davinci Resolve 12 via XML (XML v7 I think).
then graded in davinci resolve and export final cut round-trip preset with individual clips setting. (DNxHD 180 MOV format)
FCX won't open the xml file.
I had to manually insert the graded clips to the timeline but found that all the clips are a bit shorter than the original clips!!!
I have few clips that are full second short and thus not usable!
the project shot with BMCC, go pro 3 and sony rx100 m2
what is wrong?
Please I need your help as soon as possible.
David Roth Weiss
Re: Resolve render shorter clips than original!
on Mar 1, 2016 at 8:07:44 pm
Possibly a handles issue. Check your handles setting in Resolve - maybe it's not set, maybe it's set too high or too low?
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Glenn Sakatch
on Mar 2, 2016 at 3:24:29 pm
Do you have consistant frame rates between projects?
Glenn
Eli Bierwag
on Mar 3, 2016 at 5:57:21 pm
Definitely check the handles and the project frame rates as mentioned above.
Having good sized handles is particularly important if you have done any time remapping. There is always a chance for discrepancies between Resolve and your editing software when it comes to time remapping/warping. Having a decent handle length (I use 2 seconds) generally avoids these issues.
