Lightbox button in Dual Screen mode
COW Forums : DaVinci Resolve
Francois Driessen
on Jan 20, 2016 at 11:25:35 pm
Ha. I can't for the likes of me find the LIGHTBOX button anywhere if I'm running R12 in dual screen mode. The only way to engage it is to hit the shortcut or through the WORKSPACE menu item on the menu bar. Is this a bug or am I missing something here...? Anyone else out there running dual monitor mode that uses LIGHTBOX?
Francois
FireTrigger Inc.
http://firetrigger.com
Peter Chamberlain
Re: Lightbox button in Dual Screen mode
on Jan 21, 2016 at 1:10:04 am
in v12 the Lightbox button is available when you turn off clips.
Francois Driessen
on Jan 21, 2016 at 2:51:02 pm
Hi, P.
Tried that already. Don't know what you're seeing but even with Clips on or off there's no appearance of the Lightbox button for me. Are you running dual screen mode?
Switching to Single Screen mode the Lightbox button is there. Fine and dandy as it should be. But it's nowhere to be found on Dual Screen layout. I can still engage it via shortcut. But there is no UI button.
Francois
FireTrigger Inc.
