Last seconds of audio missing
COW Forums : DaVinci Resolve
Urten Ekran
on Nov 22, 2015 at 4:41:47 pm
I shot on the BMPCC with ProRes 422 and an external recorder. I then synced the clips in Pluraleyes, exported by keeping the video and only changing the audio.
So I got perfectly synced ProRes clips. So far so good.
The problem is in Resolve: When I import these clips, the last seconds of the audio is missing.
Opening them in VLC Player or Premiere Pro CC 2015 works fine.
I also tried transcoding only the audio of the clips, but this didnt help either.
Any ideas how to fix this?
Michael Gissing
Re: Last seconds of audio missing
on Nov 23, 2015 at 2:14:52 am
Which version of Resolve. I found audio weirdness like that in older versions. A lot of audio improvements have happened with Resolve 12 so it might be as simple as using the latest version
Urten Ekran
on Nov 23, 2015 at 7:52:59 pm
Indeed. I had 12.0.0 but not the November release (12.1.0)- Update solved the issue. Thanks!
