XAVC Intra UHD on a MXF delivery
COW Forums : DaVinci Resolve
Juan Carlos Aguirre
on Oct 9, 2015 at 9:11:48 pm
Hello Everyone.
I have a client request to deliver masters in XAVC Intra UHD on a MXF container.
I anyone have a experience on it, and if there any way resolve can export in this format.
In the specs, codec required is H264 at all, but not sure is we can conform on MXF.
Any direction is very welcome
Below is the full specs:
Essence container MXF OP1a (SMPTE 378M)
Video essence
Essence format XAVC QFHD Intra (Class 300)
Codec H.264 (AVC)
Format profile High 4:2:2 Profile @ Level 5.2
GOP I-frame only
Bit rate Approx. 500 Mbps (VBR/CBG)
Width 3840 pixels
Height 2160 pixels
Aspect ratio 16:9
Frame rate 50 fps
Scan type Progressive
Chroma subsampling 4:2:2
Bit depth 10 bits
Audio essence
Essence format AES-3 (SMPTE 382M, multi audio tracks, ungrouped)
Audio coding PCM uncompressed
Sampling rate 48 kHz
Channel configuration 8 OR 16 audio tracks (1 channel per track)
Bit depth 24 bits
Juan Carlos Aguirre
HTV Studio
http://www.htvstudio.com
Ritz Carltn
Re: XAVC Intra UHD on a MXF delivery
on Mar 31, 2016 at 2:12:32 pm
As my experience, it has transcoding feature in Media management or , DaVinci Resolve,
in case of DaVinci Resolve, it just transcoding with Non-drop Frame, it was different the way of edius and Davinci Resolve
so you better check the quality between Davinci and Edius.
I think Edius is better than Davinci, not sure
Ritz Carltn
