tiff stills imported as sequence
COW Forums : DaVinci Resolve
Damien Molineaux
on Sep 10, 2015 at 8:42:24 am
I'm pulling out my hair. I have project with a lot of stills in it, and they are coming in as sequences, probably because they have similar names. Davinci Resolve will make sequences of 2 to 3 images which are then not included in the sequence in Resolve and replaced randomely by another piece of video.
When I try to force conform it says their is not enough media. I've been renaming and reimporting the images one by one, but even then it sometimes does it again. I't's getting comlicated finding names that I can still figure out which image is which and yet not have sequences in the names.
Is there a simple solution to my problem? A way to import tiffs as stills and not as sequences.
Thank you for your help.
Damien
__________________________________________
C-SIDE PRODUCTIONS / EARTHLING PRODUCTIONS
Production, Rental & Post-production
8 rue de la Coulouvreniere|1204 Geneva|Switzerland
http://www.c-sideprod.ch / http://www.earthling-prod.net
Damien Molineaux
Re: tiff stills imported as sequence
on Sep 10, 2015 at 8:45:27 am
PS MacPro 3.5 GHz 6-Core Intel Xeon E5 (end 2013), Resolve 11, XML import from FCPX
Sascha Haber
on Sep 10, 2015 at 11:02:37 am
Sure, just get a good file renamer ( http://www.publicspace.net/ABetterFinderRename/ )
and get rid of those pesky numbers.
Teach tour grapghic people name structure and have em name pictures with Letters , hexa dezimal oder something else instead.
Or just ad a letter behind the name.
If stills are imported as stills they are of infinitive length
Resolve 11.3 - Smoke 2015 EXT1 - Sapphire 8
Colorist / VFX Guru / Aerial footage nerd
http://vimeo.com/saschahaber
https://dk.linkedin.com/in/saschahaber
Damien Molineaux
on Sep 10, 2015 at 12:21:33 pm
Hi Sascha,
Thanks for your suggestion. Yes I have "A better Finder Renamer" but it will be a lot of work at this stage. Renaming is quick sre but then all the files will need to be relinked. This is a 1 hour documentary film with 3 To of rushes, of all types, archival, shot for the film, stills, animation, etc.
Is there no way, either in Davinci to import tff image as stillsm or from FCPX to export an XML that somehow says theses are still images?
Cheers,
Damien
Peter Chamberlain
on Sep 10, 2015 at 3:49:18 pm
In the media storage options on media page, select the option to show all files. In this mode you can select individual clips in stills.
Damien Molineaux
on Sep 10, 2015 at 4:35:14 pm
Hi Peter,
That sounds exactly like what I need, but I cannot find this option. I went through the Resolve manual but cannot find a reference to this option. Can you tell how to do this please?
Kind regards,
Damien
Guillem Ventura
on Jul 13, 2016 at 1:31:49 pm
Yeah, I couldn't find that either...
It'd be a good option, sometimes files come from other editing programs already used (in my case it's the subtitles for a feature film, named subtitle_001.png, *_002.png, etc.)
http://www.malgeniofilms.com
Rohit Gupta
on Jul 13, 2016 at 2:33:42 pm
The option is in the 3 dots menu at top right of media storage section.
Mathew Farrell
on Feb 17, 2018 at 4:15:49 am
[A couple of years later]
The "Show Individual Frames" option is a great solution, though I get this problem when importing am FCPXML with stills. How do we avoid stills sequences in this sort of instance?
Mathew Farrell
flowstate.com.au
Michael Gissing
on Feb 17, 2018 at 4:39:05 am
I pre import my media before loading the xml file rather than getting the media to import when running the xml. So that way you can set the show individual frames when you import the media. When I import the media I choose the option to preserve folders and sub folders (right mouse click)
Once the media is correctly in then run the xml. If fo any reason stills are showing as a sequence, delete and reimport with the individual frames option selected. Fiddly.
Mathew Farrell
on Feb 17, 2018 at 5:50:01 am
Thanks Mike. I was wondering if pre-importing would solve it (but hadn't got around to trying). It's not the worst workflow, but also not as clean as it ought to be.
It's the 21st century, and conforming is still painful.
Mathew Farrell
flowstate.com.au
Michael Gissing
on Feb 17, 2018 at 7:05:57 am
If you get any input into the process, make sure that any still images do not have any repeat names and numbers in them unless they are an image sequence.
Mathew Farrell
on Feb 17, 2018 at 7:13:18 am
From a Resolve point of view, that's a good idea, though every decent stills (and video) naming structure I know has a number sequence at the end. I suspect it's something I'm just going to have to deal with for the time being.
Mathew Farrell
flowstate.com.au
Michael Gissing
on Feb 17, 2018 at 7:16:17 am
Put the number at the beginning?
Michael Gissing
on Feb 17, 2018 at 7:17:46 am
Or use file renaming software to add text at the end so it doesn't look like a numbered sequence
Mathew Farrell
on Feb 17, 2018 at 8:02:55 am
Far from ideal, but could do. Or adding unnecessary characters at the end could do it too.
Mathew Farrell
flowstate.com.au
