Import multi sequences from Premiere in a single XML ?
COW Forums : DaVinci Resolve
tiphaine buccino
on Aug 13, 2015 at 2:48:32 pm
Hi all,
I have a project in which there are many sequences I have to grade. I have made a xml file with all the sequences but I can't find a way to import it in Davinci Resolve (12.0.2) in one time.
Davinci propose me to select one sequence at a time :( and I'm wondering if there is a solution to select all the timelines/sequences that are in the xml to import it all at once !
Thanks guy !
Marc Wielage
Re: Import multi sequences from Premiere in a single XML ?
on Aug 14, 2015 at 5:07:40 am
Not that I can see. You'd have to prep all the scenes in an edit program and create one timeline, then export that XML and then import it into Resolve to conform the timeline.
The alternative would be to bring in each XML one at a time in a separate timeline, then select all the clips in each timeline and copy and paste them into a single timeline... but it'd be a lot of trouble. Could be done, depending on what the timecode is for each sequence.
