Gamma-Shift
COW Forums : DaVinci Resolve
Eric Sternberger
Gamma-Shift
on Jul 20, 2015 at 10:45:15 am
I see a gamma-shift when exporting to DNxHD from ProRes.
see the Screenshot for reference:
in the image to the right you see the ProRes Version, left is DNxHD.....
The ProRes-File was imported to Resolve put in a timeline and exported again.
There was no filters applied, colors corrected....
Sascha Haber
Re: Gamma-Shift
on Jul 20, 2015 at 4:09:05 pm
Classic scaling error.
You are rendering video to data accidentally.
Change your project setting, viewing settings, interpret footage correctly. Done.
Resolve 11.3 - Smoke 2015 EXT1 - Sapphire 8
Colorist / VFX Guru / Aerial footage nerd
http://vimeo.com/saschahaber
https://dk.linkedin.com/in/saschahaber
Eric Sternberger
Re: Gamma-Shift
on Jul 21, 2015 at 11:37:19 am
Thanks, Sascha!
In the Rendering Tab "Video/Data Level" was set to Auto.
Setting it to "Video" solved this...
Marc Wielage
Re: Gamma-Shift
on Jul 21, 2015 at 2:46:38 am
The differences will be more apparent (and measurable) if you use SMPTE bars and/or a full-screen grayscale and check the scopes. This will give you the clues towards the workflow you need to follow.
