Resolve 11 AAF to Avid Error
COW Forums : DaVinci Resolve
Shane Ross
on Jun 14, 2015 at 7:37:50 am
Hey all. I've sent a small test sequence from Avid to Resolve 11, to check out the workflow. The footage is from a C300, I transcoded it to DNx175, then exported an AAF, imported to Resolve, and did a cursory grade. I then rendered out the footage, put it into the Avid file structure, and then exported an AAF out of Resolve.
I can import that fine into Avid...but when I open the sequence, all the media is offline, and I'm hit with two errors:
and
And then I get debugger error, and then an EXCEPTION...and crash.
Anyone help me with this one...am I doing a step wrong? If I load the .mdb into a bin, all the footage comes in fine.
Shane
Little Frog Post
Shane Ross
Re: Resolve 11 AAF to Avid Error
on Jun 14, 2015 at 6:44:21 pm
Semi-solve...in the RESOVE forum..
Shane
Little Frog Post
Evan Anthony
on Jun 14, 2015 at 10:01:57 pm
and..?
Shane Ross
on Jun 15, 2015 at 8:47:10 am
Sorry, I mean solved on the Avid forum.
https://forums.creativecow.net/thread/45/901128
In short...export>Generate NEW AAF. That solved it.
Shane
Little Frog Post
Joseph Owens
on Jun 15, 2015 at 3:56:31 pm
[Shane Ross] "In short...export>Generate NEW AAF. That solved it."
You will get a new timeline, true... but its not really a solution for seamless round tripping, because your new AAF is basically a virgin project and will not contain any of the unsupported Media Composer functions that would ordinarily be carried back and recreated in the original MC project sequence.
Better than nothing, though.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Shane Ross
on Jun 16, 2015 at 6:55:35 am
Hmmm...then I hope it works like normal when a real project hits my table.
Shane
Little Frog Post
