25 Frame rate export
COW Forums : DaVinci Resolve
Vivian Xavier
on Jun 13, 2015 at 10:26:19 pm
I i made a timeline for 24fps but the client wants a 25fps export. I have already colour graded the shots. So how can i export it at 25fps?
Marc Wielage
Re: 25 Frame rate export
on Jun 14, 2015 at 3:20:15 am
You could export a flattened file at 24fps in a high-res/low-compression format like ProRes 444 (or even DPX), then start a new session at 25fps, bring the flattened file back in as a round-trip, then re-render it all at 25fps. They will have to make a corresponding change in the audio mix to adjust for the 4% speed up (4.1% speed up if 23.976 vs. 25fps).
