Copy/paste OFX keyframe animation in DaVinci Resolve Lite
COW Forums : DaVinci Resolve
Vasilis Miltiadis
on May 28, 2015 at 5:13:01 pm
Hi, I have a Particle Illusion OFX node, and I've also created a simple animation moving an emitter around. I'm facing two issues here.
One, I want to loop the animation but I can't find a way to copy/paste the keyframes next to each other. I can select them all with SHIFT but there's no right-click menu, and CTRL-C/CTRL-V doesn't do anything. I could of course copy the node, but that makes the emitter restart, and spoils the effect I'm after.
The second issue I already wrote about in the Particle Illusion forum here, but since I don't know if it's a Resolve quirk, I'll outline it here as well. The emitter doesn't react to the movement like in the preview window, it leaves no trail behind, and it doesn't bend at all.
Any ideas?
