Easy way to share entire project worth of grades?
COW Forums : DaVinci Resolve
Steve Kennedy
on May 21, 2015 at 1:20:55 pm
I understand you can easily share the grade for a single shot by exporting a still (DPX / DRX). But if someone has an entire project, with many hundreds of shots, is there an easy way to share those without having to export each shot individually? Is there just a way to share the project?
S
Vincenzo Onorato
Re: Easy way to share entire project worth of grades?
on May 21, 2015 at 3:14:47 pm
Hi Steve, you could try in this way:
grade your project
save all stills from first or middle frame
copy all stills in folder
create a new power grades album
paste all stills
export the entire project + an XML/AAF/EDL
Be sure that the saved stills contain all nodes at each level (timeline, pre-clip, post-clip)
V.
Joseph Owens
on May 25, 2015 at 5:43:02 pm
File:
Export:
Project
Save to /folder/directory (include stills?)
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Steve Kennedy
on May 25, 2015 at 6:11:29 pm
Ha, yes. It really is that simple. I seem to remember using an older version of Davinci where it was much harder to share projects, but perhaps I was mistaken even then.
Ali Quintana
on May 25, 2015 at 11:15:27 pm
OK, thats a great way, is there also a way to archive all the footage used?
Like archive a folder with the Davinci file and all footage?
