Error Message when rendering.
COW Forums : DaVinci Resolve
Christian Vilderman
on Apr 27, 2015 at 12:45:38 pm
Hi
Can anyone help?
"davinci recording failed with error the video format is not supported"
I get above error message from Davinci 11 when trying to render. Windows 8.1 user
I want to render a 4096x2160 Quicktime Cineform RGB 16BIT. I tried different ssd's etc and this didn't work. It is either crashing straight away or just comes up with the above error message. It never even starts rendering. I also tried only rendering individual clips to no avail.
I tried rendering Quicktime MPEG VIDEO which works fine...
All I am looking to do is export the highest quality render I can possibly get. If that means a different codec other than cineform than so be it. I am a windows user so Proress is obviously not a option.[/b]
My system specs:
5960x 4.0ghz cpu
32gb ram
titan X gpu
windows 8.1
Davinci 11
and loads of storage drives.
Thanks!!!!!
Stefan Sarkuso
Re: Error Message when rendering.
on Sep 28, 2015 at 4:42:36 pm
same here with resolve 12 final version and windows 8.1 64bit.
did you make any progress on that?
Andy Winter
on Sep 29, 2015 at 5:27:24 pm
why not render dpx or openexr?
Stefan Sarkuso
on Sep 30, 2015 at 11:38:50 am
Situation is that: I have 4k h264 footage from the Panasonic GH4. I want to use it in a more editing friendly codec and found "Filmscan 1 / High setting" of Cineform codec gives me a good ratio of file size and quality. I also want to use it in Premiere CC 2015.
And to be frank, I am not familiar with DPX or OpenEXR. If you can explain me, what flavour of these codecs gives me the equality of "Filmscan 1" it would help me!
Thanks for your time!
Stefan
