Color Temperature Node
COW Forums : DaVinci Resolve
Gregor Willers
on Mar 22, 2015 at 8:48:42 pm
Hey Folks,
I'm a little frustrated. Is there an option in Davinci Resolve 11 to change the color temperature in a node?
(I want to mix to nodes with different color temperatures and LUTs)
I'd be very happy if someone knows an answer!
Tero Ahlfors
Re: Color Temperature Node
on Mar 23, 2015 at 4:56:36 am
RAW footage has a color temp option in the RAW settings. Otherwise you'll have to do it manually.
Gregor Willers
on Mar 23, 2015 at 8:33:14 am
Thx Tero for your fast answer!
I have RAW footage (Red DRAGON) and i've changed the color temp in the RAW settings. But is there an option to change the color temp in a node? Couldn't find anything.
Marc Wielage
on Mar 24, 2015 at 6:05:25 am
Yes. Assuming you're dealing with Raw files, create a new node, then select the Camera Raw screen mode, go to Clip, and then change the color temperature as needed. I personally like to adjust the camera raw settings as the very first node (or even in a Pre-Clip group), but that's my preference.
