From source viewer to timeline
COW Forums : DaVinci Resolve
Roy Feldman
on Mar 9, 2015 at 10:25:28 am
Trying to learn editing with DR, have used other editors before.
In the edit source window after selecting in-out, is there a way to just insert (into time line) the audio only or video only portion of the selected. Every other editor I've used has had this availability to choose audio, video or both.
Joseph Owens
Re: From source viewer to timeline
on Mar 11, 2015 at 3:41:28 pm
[Roy Feldman] "Every other editor I've used has had this availability to choose audio, video or both."
"You can also disable the video or audio destination controls in situations where you want to edit a source video clip into the Timeline without its audio, or vice versa.
To disable or reenable a destination control, do one of the following:
--> Click an already assigned destination control to toggle it off and then on again."
The destination controls are the icons found in the timeline header.
Its very much like the patch field connectors in the Final Cut timeline header.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
