how to change scaling mode (or do other transformations) of multiple clips
COW Forums : DaVinci Resolve
Andrew Davydov
on Mar 3, 2015 at 12:01:59 pm
I've searched for this everywhere I could.
I'm working in the last light version of Davinci Resolve. The problem appears in the edit tab. I have an anamorphic clips in my timeline along with normal clips. The timeline resolution is 1920x816.
My question is, how can I transform the vertical scale of a selected clips all at once? I can do this to each clip one by one, but this takes a long time.
Any help would be appreciated.
Sorry for my poor English.
Andrew.
Dmitry Kitsov
Re: how to change scaling mode (or do other transformations) of multiple clips
on Mar 3, 2015 at 2:30:55 pm
Hello Andrew. Use a right click in a media tab after selecting multiple clips, to which the adjustment must apply. Then click on a "clip attributes" in a context menu. There you should be able to select an appropriate pixel aspect ratio in a video portion of the clip attributes panel.
Andrew Davydov
on Mar 3, 2015 at 11:18:30 pm
Dmitri thank you for reply.
That did what I needed :D
