Interpolate between Dynamic Keyframes
COW Forums : DaVinci Resolve
Randy Rubin
on Feb 6, 2015 at 9:05:25 pm
Hi There,
I have two dynamic keyframes and I am try to animate my primary correction. Instead of interpolate between the keyframes, the correction changes when it hits the second keyframe.
I've made sure both keyframes are 'dynamic'. Am I missing something?
Margus Voll
Re: Interpolate between Dynamic Keyframes
on Feb 8, 2015 at 9:58:58 pm
Seems lik a bug to me.
I have had this many times.
In any case try to zoom in as much as you can to see it not double keyframes in one spot
1 frame a part.
Margus
http://iconstudios.eu
Resolve 11
BMC 2,5k
Sascha Haber
on Feb 9, 2015 at 8:40:10 am
Yes, i had the same problem here and there.
I happens when you have two keys , cut the clip and place a third one then in the middle , for example.
That is one of the reasons why we need a proper keyframe editor.
We all make dumb mistakes but it would be good to look at it after and be able to fix it.
If the situation here occurs i tend to break the shot and just add a dissolve between the two grading points.
Which has way more control and you don't have to worry about any keyframes :)
Resolve 11.2 - Smoke 2015 EXT1SP2 - Sapphire 8
Colorist / VFX Guru / Aerial footage nerd
http://vimeo.com/saschahaber
https://dk.linkedin.com/in/saschahaber
tiphaine buccino
on Aug 8, 2015 at 10:07:29 am
Thanks a lot guys ! You save me from a nightmare !!
