trim lut
COW Forums : DaVinci Resolve
paulson lang
trim lut
on Feb 1, 2015 at 6:11:42 am
I am not able to generate lut through "generate lut from current grade" option.The lut generated is giving distorted colors.Do i have to use a lut in order to generate lut from this option? pl help.
PL.
Toby Tomkins
Re: trim lut
on Feb 1, 2015 at 11:21:53 am
Make sure you don't have any power windows or otherwise isolated secondaries. Qualifiers can be OK but I would recommend having them quite 'soft'.
Rohit Gupta
Re: trim lut
on Feb 1, 2015 at 12:28:07 pm
You are right clicking on the color page thumbnail to generate it right?
The project settings options requires the special trim_lut DPX file and it should be required anymore. Use the color page function.
paulson lang
Re: trim lut
on Feb 1, 2015 at 6:12:04 pm
Thanks Rohit, It worked.
