Can you apply stabilisation to just a node?
COW Forums : DaVinci Resolve
Scott Clements
on Jan 27, 2015 at 8:14:41 pm
I saw a tutorial saying to make a node to apply stabilisation to, but this doesn't seem to work for me. It appears to apply stabilisation to the clip, not a node. Is it impossible to apply stabilisation to just a node?
Glenn Sakatch
Re: Can you apply stabilisation to just a node?
on Jan 28, 2015 at 3:21:07 pm
If you are on a node and you go to your tracker and switch it over to stabalizer, then you are now stabalizing the node.
Is that what you are asking?
Glenn
Scott Clements
on Jan 28, 2015 at 4:09:20 pm
Yes, that's what I'm asking. But that is not the case for me. I will click on a node an stabilise and then I can delete the node and the stabilisation will still be there. The only thing that removes the stabilisation is deleting all the tracking data.
Film Editor, London UK
http://www.scottclementseditor.com
Joseph Owens
on Jan 28, 2015 at 5:02:14 pm
No, you need a node to start applying any form of correction or operation... but stabilization itself is not part of the node-tree, it is a clip-oriented process.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Scott Clements
on Jan 28, 2015 at 5:11:59 pm
Thanks, Joseph!
