Correctly archiving Projects?
COW Forums : DaVinci Resolve
Florian Gintenreiter
on Jan 8, 2015 at 9:01:38 pm
I have graded a feature-film last year. I worked on the grade way before editing was finished and picture-lock took a while, so I had all the camera-footage on my media drive so that I could swap or replace a shot easily if need be and believe me that need did arise.
Now that the film has been released and final tweaks are done I wanted to archive the project off my main Raid to a backup location. There is no need for me to keep all the camera-footage that is not used in the cut, because it's backed-up elsewere but I want to archive all the media that's in the cut to be able to quickly change something should the need arise.
In order to do that I followed the steps outlined in the DaVinci 11 Manual (November 2014 Edition) on page 381.
- Consolidated all the clips used in the Timeline to an external location, preserving the directory-structure. (I consolidated the whole source clips and did not trim them.)
- Saved the Project under a new File-Name
- Removed all the clips from the media pool
- Right-clicked the sequence in the Edit/Timelines view and did Import > Additional Clips With Tight Filename Match
- The timeline was now referring the the consolidated files at the backup-location, but all the grades were removed from the timeline.
I solved that bay using color-trace and used the timeline still pointing to the original media-files as a source and thus was able to put back all the grades on my timeline pointing to the archived media, but I doubt that was the correct way of doing this. Had I not saved a copy of the project before I removed all the clips from the timeline, I would have lost my grades for good.
It seems removing the clips from the media-pool also removed their grades even though the timeline was still in the project.
How do I correctly do what I did in the future?
cheers
Florian
________________________________________
Director of Photography, Director, Editor
Vienna, Austria
Margus Voll
Re: Correctly archiving Projects?
on Jan 8, 2015 at 9:26:00 pm
If you have same names and tc in consolidated files then trimmed files should connect correctly without colortrace.
Margus
http://iconstudios.eu
Resolve 11
BMC 2,5k
Glenn Sakatch
on Jan 9, 2015 at 3:18:49 pm
If you are keeping all the source files used...not trimming anyway, I would just export the final version of your project.
If you want to rebuild it, import that project, select the clips in your media pool, and do a "change source folder" to the location of your consolidated clips.
Same as if you had to switch hard drives at some point or transfer the project to another system.
Glenn
Clark Bierbaum
on Jan 10, 2015 at 1:05:07 am
Can't say enough good about: http://www.niwa.nu/resolve-collect/ if on Mac. Great tool!
Sascha Haber
on Jan 10, 2015 at 12:45:04 pm
The link is not working
You will find it here :
https://itunes.apple.com/dk/app/resolve-collect/id668433918?mt=12
A slice of color...
Resolve 11.1.2 - Smoke 2015 - Sapphire 8
Colorist / VFX Guru / Aerial footage nerd
http://vimeo.com/saschahaber
