Avid to Da vinci issue
COW Forums : DaVinci Resolve
Laura futuro
on Dec 8, 2014 at 5:17:27 pm
We are editing on AVID MC8. I exported and offline reference clip from avid SAS (same as source) which is DNxHD 36.
When importing the midia on Da vinci Resolve in order to use it as a pass through to make fasters H264, Da vinci turn some of the clips BLACK.
Usually clips that were either on the V2 or clips that start with a black.
When checking in the QT all the image is there.
For instance, the final credits, at the end of the movie, when it goes do black Davinci reads all to the final as a Black clip, when I opened in quicktime I saved just the credits (without the black at the beging) and then imported it at Da vinci and then it's ok.
So its not a codec issue, since it read, but might have something to do with the black at the beging of the image or with the fact that originaly it was on V2.
I tried in 2 different machines with resolve lite and it's all the same.
Does anyone had the same problem and know how to solve it.
The solution a gave was to use another software to export the h264 from the SAS, but on da vinci that would be much quicker since my graphics are very good...
thank you in advance already
