Retiming clip to 120%
COW Forums : DaVinci Resolve
Pradeep Sen
on Dec 1, 2014 at 6:46:09 pm
Hi there,
For a project, I would like to use DaVinci Resolve to retime a clip to 120%. However, when I go to the Retime menu, the speed options are only 110%, 150%, 200%, etc.
How do we retime to custom values with Resolve?
Thanks in advance!
Joseph Owens
Re: Retiming clip to 120%
on Dec 1, 2014 at 10:39:01 pm
You should be able to type in almost any number, bearing in mind, of course, that the application will round off to some nearest number, just like they all do.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Aurie Anden
on Dec 2, 2014 at 7:41:50 am
Hi Pradeep.
Instead of choosing "Retime Clip" from the Menu, try using "Change clip speed" right on top of it. You should be able to type in the exact adjustment you want in terms of % of the frame rate.
hope this helps.
Cheers.
aurie
Vincenzo Onorato
on Dec 2, 2014 at 8:47:23 am
You can also press cmd+R and drag the topmost part of the clip on the right side. It should appear a little black arrow near the clip name
V.O.
