Progressive footage showing interlacing artifacts?
COW Forums : DaVinci Resolve
Justin Crowell
on Nov 23, 2014 at 4:43:16 pm
Hi all,
I've received 5D footage converted to ProResHQ. When I open the footage anywhere besides Resolve, it looks fine, but when I open in resolve, it looks like it's trying to show interlaced footage (pictured below). I don't see any options to deal with field dominance anywhere. Can somebody help?
Justin
Editor, Producer, DP
JustinCrowell.com
Dmitry Kitsov
Re: Progressive footage showing interlacing artifacts?
on Nov 23, 2014 at 6:01:33 pm
There are might be multiple reasons for what you are seeing. 1- the way footage was actually converted. What was used to do so? How does it show up in Resolve? What frame rate? Is it goes same frame rate as expected? If you bring in the original doesn't behave the same way? 2- Do you have field processing turned on in the project settings? It shouldn't be on for progressive footage. 3- check clip attributes (right click on a clip in the media pool) does the framer are field dominance setting make sense?
