Edit Page playback
COW Forums : DaVinci Resolve
Perry Trest
Edit Page playback
on Nov 6, 2014 at 3:17:13 pm
Since upgrading to 11.1.1, the edit page is doing some very strange things. May have to back up to 11.1 but I thought I would run this one by you guys.
My current project contains Sony F5 2k raw media that appears in the media pool as .mxf.
The timeline is 1920x1080 @ 23.976fps.
Every time I enter the edit page, playback slows to 5fps +/-.
Example:
I'm working in the color page as normal, everything good.
I enter the edit page to make a change to the timeline and playback hits 5fps.
Back to the color page and it also will now only playback at 5fps.
I have to close Resolve and re-launch to re-gain 23.976fps.
As long as I avoid the edit page everything works as expected.
I have the latest Cuda drivers running on OS 10.9.4
The media is on a USB3 drive connected via a Caldigit USB3 PCI card.
Anybody else seeing this?
Thanks in advance.
Perry Trest
POSTDIGITAL, Inc.
http://www.perrytrest.com
OS 10.9.4
Davinci Resolve 11.1 Licensed
MacPro 12core 3.33Ghz (2010)
32GB RAM
Slot 1 = GTX780 6GB GUI
Slot 2 = Cubix Xpander
Slot 3 = DeckLink SDI
Slot 4 = Nitris DX
Cubix Xpander = GTX780 6GB GPU + Caldigit eSata/USB3
Internal 6TB soft RAID-0
Euphonix Artist Color
Flanders Scientific CM170
Davinci Resolve 11 Lite
iMac 27" 2.7GHz Quadcore i5
20GB RAM
Blackmagic Mini Monitor
Peter Chamberlain
Re: Edit Page playback
on Nov 7, 2014 at 1:05:02 am
Hi, can you post a link to a few seconds of the clip?
Perry Trest
on Nov 7, 2014 at 3:57:49 pm
https://www.wetransfer.com/downloads/57a62f538326051f28e858365e9f402b201411...
Perry Trest
POSTDIGITAL, Inc.
OS 10.9.4
32GB RAM
Slot 4 = Nitris DX
20GB RAM
Sascha Haber
on Nov 8, 2014 at 10:19:28 am
Hi Terry,
I tested the footage on my new MacPro 6 Core 2x D700 under 10.10 and it plays just fine.
Both in the color page with a couple of nodes and also in the edit page and media pool.
However, if I try the same on the company system which looks a lot like yours, it stutters too.
We had the problem with a lot of the XAVC footage and decided to go with a ProRes conversion done in the Sony tool provided.
Also because AVID was very unhappy with the codec as well.
A slice of color...
Resolve 10.1.4 - Smoke 2015
Colorist / VFX / Aerial footage nerd
http://vimeo.com/saschahaber
Perry Trest
on Nov 8, 2014 at 9:40:05 pm
Thank you for testing this Sasha.
What I've found after further investigation is that if I place a single clip in a new timeline by itself, it plays perfectly in media, edit, and color. But when there are multiple clips in the timeline (22 minutes trt in this case) playback drops to 5 or 6fps if I switch to the edit page and hit play.
To reiterate, this only occurs with F5 footage. If I avoid the edit page during a grading session, everything works as expected. If I switch to edit page and press play, I end up having shut down and restart Resolve. Unfortunately my client does not want his footage transcoded to ProRes prior to grading.
Perry Trest
POSTDIGITAL, Inc.
OS 10.9.4
32GB RAM
Slot 4 = Nitris DX
20GB RAM
Margus Voll
on Nov 19, 2014 at 7:21:45 am
I see similar thing on my 5.1 but with some material and not sure if the same amount
you have.
What sometimes fixes it for me is zooming in a bit as the lag seems to me stronger
when all zoomed out like UI refresh would do that.
Margus
http://iconstudios.eu
https://vimeo.com/iconstudioseu/videos
DaVinci 10, OSX 10.8.5
MacPro 5.1 2x2,93 24GB
GUI 4000 / GPU GTX 780
DL 4K
Eizo Color
Scope Box
Full Ligthspace CMS
