Spacial NR causing blocking pixelation
COW Forums : DaVinci Resolve
Nat Jencks
on Oct 30, 2014 at 2:17:23 am
I'm on the most recent build of v11 and seeing an issue where spacial NR is causing pixelation / blocking. As if it was being reduced to a lower resolution. Workaround is to use NeatNR for now, but its annoying.
I have not seen this before. Anyone else seeing this? This particular system is a nMP 12core 2xD700 64GB RAM
best-
-Nat Jencks
Andy Winter
Re: Spacial NR causing blocking pixelation
on Oct 31, 2014 at 10:50:26 pm
can you post a picture?
Robert Ober
on Oct 31, 2014 at 11:09:23 pm
[Nat Jencks] "I'm on the most recent build of v11 and seeing an issue where spacial NR is causing pixelation / blocking. "
Only on playback or did you actually output a file and it has the issue?
Curious,
Robert A. Ober
