Restore old database
COW Forums : DaVinci Resolve
Timo Teravainen
on Oct 9, 2014 at 9:46:11 am
Hi, I have a problem restoring an older database on Resolve 11.1. When I choose Restore on the Database Manager and select the .backup file, theres first the step of creating a new database to restore to (Driver: QPSQL, the DISK option is grayed out) and then it asks to "please select the 'bin' directory in the PostgreSQL installation." I don't have the old database installation on my machine, that's the reason I have made backups from my old database.
The database that I have on my system (Windows) is disk based.
Dwaine Maggart
Re: Restore old database
on Oct 15, 2014 at 11:43:03 pm
See if you can create a new QPSQL database. This will see if you have PostgreSQL properly running on your system.
If you can't create a QPSQL database, run the Resolve installer and see if it thinks PostgreSQL is already installed or not. If not, check the PostgreSQL box and install it.
Dwaine Maggart
Blackmagic Design DaVinci Support
