copy grade timeline node
COW Forums : DaVinci Resolve
Israel Diaz
on Oct 9, 2014 at 9:03:48 am
Hello I will like copy the grade in the timeline node not in the clip or put in the galley .
it is posible??
Thank you
Marc Wielage
Re: copy grade timeline node
on Oct 9, 2014 at 10:04:17 am
Well, you can copy grades with command-C or control-C and then paste them, if that's what you mean. Do you mean one grade for the entire timeline? I have to admit, I've never tried copying a grade in that mode, but I bet it could be done. At worst, you could open up the node graph and drag over the specific nodes you wanted, if there was a reason for applying a grade to the entire timeline.
Israel Diaz
on Oct 9, 2014 at 10:13:33 am
OK I find the solution.
When you duplicate a timeline, the timeline node grade not past to the copy, you need select and save in a memory to paste to new timeline.
prathvish hegde
on Oct 10, 2014 at 6:47:59 am
ColourTrance is the answer
prathvish hegde
colorist
(DaVinci Resolve and 2Kplus)
http://www.youtube.com/playlist?list=PLRPJQ3fIEoojI3JMa4rHKb9gqq8VeIZ81
