mxf-DNxHD-delivery
COW Forums : DaVinci Resolve
Eric Sternberger
mxf-DNxHD-delivery
on Oct 8, 2014 at 10:25:45 am
again mxf:
I want to deliver an mxf with Avid DNxHD-Codec(originating from a ProRes-Master).
I choose the according settings in the deliver-tab. resolve outputs the file.
...but mfx4mac can´t play it. also, if we want to import it into resolve, the file can´t be chosen from the list at all. so there´s something wrong - but what?
Joseph Owens
Re: mxf-DNxHD-delivery
on Oct 8, 2014 at 5:40:58 pm
[Eric Sternberger] "I choose the according settings in the deliver-tab."
Can you furnish us with the exact details of how the export was configured?
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Eric Sternberger
on Oct 9, 2014 at 9:01:47 am
please see the settings in the pics attached:
Joseph Owens
on Oct 9, 2014 at 5:38:16 pm
Yikes.
The MXFOP1A container is a Sony XDCam-centric option designed for XDCAMHD codecs, so I really doubt that DNX would be a viable choice. Choose the plain vanilla MXF for DNX or if you really need to deliver an OP1, then it is more likely that you should be choosing an XDCam422HD codec.
jPo
Eric Sternberger
on Oct 23, 2014 at 8:28:59 am
Non OP1A works! OP1A with DNxHD in it does´t work (on my machine)
Dwaine Maggart
on Oct 16, 2014 at 12:10:12 am
This should work. I just rendered a DNxHD 1080p 36 8 bit file with 4 audio tracks in MXF OP1A format and Resolve sees it properly. I don't have mxf4mac, so not sure about that.
I repeated the test with your 1080I 220 10 bit selection, and that worked fine as well.
What version of Resolve are you on?
Dwaine Maggart
Blackmagic Design DaVinci Support
Eric Sternberger
on Oct 16, 2014 at 10:32:26 am
I´m on 11.1….
